Trying to address this issue on a 2000 Boxster S. Is this pointing me to a non-working cruise light on the dash? Where can I find detailed explanation of this error and the fix? Thanks.
:welcome:
P1576 Cruise Control Standby Lamp – Above Limit, or Below Limit, or Open Circuit
Possible causes:
– Short circuit to B+ in wiring
– Short to ground in wiring
– Break in wiring
Check wiring from DME control module, pin IV/18, to instrument cluster, pin I/16, for short to B+.
It was the cruise control light on the instrument cluster. The bulb wasn't there. Pulled it from another and put it in and it lit up. Even Durametric stopped reporting the error. Ordered a few 1.2w and 1.5 w. Some bulb receptables are empty. Aren't all of them supposed to have bulbs in them? The right most 4 do not have any. Last one would be the CC one.
The owners manual is what i do not have so ordered one and will try to match what needs to be in and working. Thanks for your help.
