Hi Fourms,
My rear left door stopped unlocking properly when I unlock all doors. I was able to unlock the door by unlocking with handle from the inside.
Using the key, the door still locks. It simply does not unlock.
Would anyone be able to tell me how I can figure out exactly what the problem is?
C.
Kessy or no Kessy?
Assuming the child proof lock is not set (see owners manual) on that one door then you will likely need a PIWIS tester to further diagnose whether it is an electrical malfunction or mechanical door lock problem.
