Hi guys i'm in a big bind... I drove the car last Saturday to go Christmas shopping and have all the wifes presents in the trunk. So i go out tonight to get them out to wrap and the key fob wont open the door or trunk??? The light on the remote is flashing but nothing!!! What to do.... Thanks
If the alarm has been armed for over a couple of days you will need to use the key in the door to unlock it and reactive the cars systems. The car deactivates it's systems and goes into a standby mode. Once you unlock the door with the key, you will need to put the key in the ignition quickly or the alarm will sound. Hope this helps.
Actually the remote mode is enable for 5 days according the manual. Then its turned off for battery economy. When you use the key to open the door put it on start within 10 sec in order to avoid alarm activation
