Are you sure it's oil? Are there any obvious leaks around that area (i.e. AOS hose, throttle body, etc.)?
Does it come back after you clean it?
Iogray,
That's a great question thanks for the reply, I did have the AOS replaced recently maybe this was residual from the earlier failure? I did replace the filter with an OEM one, I'm curious to see if the residue appears again.
