Has anyone seen a excel spreadsheet xls that can draw graphs using Durametric software data for tq/hp/afr, Brockway uses there or odb2 port to take even it think NB O2 sensors and figure out what your afr is etc with out wideband sensors on a gauge etc.
The only one I have found in .ZIP form that maybe can do it by importing excel data but have not got it to work as of yet.
Need a way to show this data like a dyno graph, trying to find out what issues are causing these 5000k issues on my graphs.
Log file Interpolation ver3p7c Jan08.zip
post-4095-0-37441100-1323551715_thumb.gi
post-4095-0-52591500-1323551738_thumb.jp
post-4095-0-21444000-1323551750_thumb.jp
Edited by Mother
No it is not but easy enough to send if you wish to try it zip file below. I have not gotten it to work yet. You can however import your data into it if you wish.
With the spreadsheet open try on menu bar excel tools-options-under security button choose macro security and pick lowest setting to allow the active x buttons to work then you can work with importing your durametric data etc
my run.zip
