Hi Fourms,
My rear left door stopped unlocking properly when I unlock all doors. I was able to unlock the door by unlocking with handle from the inside.
For safety, I decided to manually override the lock. I locked the door by taking off the manual override cap and pushing the lock in. Then closed the door.
Problem is now, I can't unlocking the door inside or outside.
Can someone tell me how I can open the door?
C.
Now you've dropped yourself in it. Call your local lock smith and he'll have to jimmy the lock using tools that slip between the glass and frame.
