May sound like a dumb question but does bank 1 O2 sensor come before or after the Catalytic Converter? I need to order a new one and just want to make sure I get the right one.
Edited by clb0099
Well, for a USA car there are two o2 sensors on bank 1.
One before the cat and one after.
Which one do you think you need to replace and why?
I used my Durametric tool and the P2096 code came up and it says aging O2 Sensor on bank 1 Delay. How do i figure which one is not good....
I did some research and it seems like the O2 sensor. The only difference in the before and after kat one is the cable length, so buy the before kat one so it will fit both places(it has the longer cable. This is what I got from seller on ebay. So I will just go to my mechanic with the O2 sensor as well as I got a tiptronic code of 50 which is impressible transmission ratio which means I need to replace the tranny fluid
