I'm obviuosly not looking hard enough, but i can't find any previous threads or info regarding the removing the bucket seats in my 2003 GT3. I'm adding a harness to the passenger side so if someone could point me in the right direction it would be much appreciated.
GT3 Seats also have a harness? D*mn..i'll have 2 rewire the stuff i cut out of my old seats. and disable that bastard airbag light.
captain chaos: depending on if the dealer put the stock 3pt belt thru the holes in the seat, you'd also have 2 unclip the belt at one point to slide it out. If you need directions for that let me know and i'll try to post the excerpts from the shop manual.
^ they mount to the side of the gt3 seat (there's a bolt there for that). i'm not sure where to mount them in the car. i'd guess that you can mount them to the same point as the stock ones. some people use the seat rails on the stock seats but i woudln't recommend it, not without some reenforcement.
Thanks, I have the GT3 seat and thats what I thought. I am told that the outside mounting point s/b where the factory belt is mounted to the car.
  • 4 weeks later...
