When I pulled the engine I forgot to mark the two main 996 engine connectors in the engine compartment. It looks like both are unique but I'm paranoid and would like to make sure. Is it possible to reverse the connectors and if so how do you tell which is which?
I believe that there is a different shape to the center of the connectors to prevent the switching of the two.
IIRC there is also a colored dot on each plug, as well as on the socket.
If not and if they are not a different shape, it should be easy enough to decipher the correct orientation using the wiring diagram.
