Doing some research on DIY 60K maintenance for my S03, and one thing I want to confirm is whether there is a need for changing the fuel filter? The maintenance book does not indicate anything about this filter and some prior forum topic indicated that this filter has been integrated with the fuel pump (not sure what that would mean...)
For cars with Return less Fuel System is no periodic replacement specified, only in case of fuel supply problems, contaminated fuel, etc. The filter is indeed integrated in the fuel pump assy. together with the fuel gauge lever arm and the fuel pump, but individually replaceable.
