I know it's thanksgiving here... But I'm in Ojai, Cali and I was doing a brake bleed before a track day Sat and the previous owner stripped one of the bleeder screws (this is the first bleed ive done on her).
Anyone in the general area that has an extra one I could buy?!
You would be my hero!!!!
Sean
If you don't get an answer from someone local, you might want to give NAPA a call - I THINK they usually have a good assortment of brake caliper bleeder screws.
If the caliper itself, rather than the valve screw, is stripped, then it can be fixed with a TimeSert insert.
  • 4 weeks later...
just now seeing this thread. I had a bleeder screw break off.... plugged it with a 5mm bolt. held up fine under pressure. no leaks of brake fluid.
how did you resolve this problem?
