I am having an irritating problem. I have a 2003 Boxster, bought secondhand in 2008, that came with two keys. This year finally, both keys started having battery problems. I replaced the batteries in both keys.
The problem I'm having is that the keys are only lasting 1-2 days. After two days or so, the keys tranponders don't work and the light barely flickers. I bought a battery tester to check the batteries and have found that the keys only work when the reading is on the extreme green (GOOD) setting. Once the battery has decreased slightly, but still in the "GOOD" range, the keys don't work because the signal is too weak.
So what's the best solution?
I called the local Porsche dealer (Santa Barbara) and they told me to get a new transponder would be $183, with a $70 reprogramming addition. I've looked at the transponders on my keys and they look to be in good condition. It's just the battery usage that's driving me nuts. Plus the rubber band that goes in both keys has been stretched out beyond hope,which makes the keys hard to seal completely.
