My shift lever rotates about a mm or so when I grip it. I know it shouldn't but how can I tighten it?
Many thanks...
Many thanks...
You might make sure it is properly locked in place. See the post here.
Thank you. That was just the info I was after.
Although I couldn't fix my problem :angry:
It appears that the surround that slots over the lever is lose. It is "keyed" into a slot on the main shaft so either this slot is too big or the bit on the surround is too small. Very odd for a brand new car.
I don't think there is anything else I can do.
