When I changed the plugs on my 01 turbo I noticed several small surface cracks (maybe 1mm deep) on all the coils, particularly on the round part covered by the rubber boot. I don't think any cracks were visible on the external part of the coils. No carbon tracks. The car runs fine, including in heavy rain. When I had the car apart I called the dealer tech and he seemed to think it was a big problem. When I took the car in for warranty work they replaced the MAF and fuel pump and cured the full load high speed miss it was having. I don't think they pulled a coil and actually looked at the cracks. The tech said he checked the coils and they were OK. I'm 99% sure he did not pull a coil for inspection. I was not mentioned on the final work order. Is this anything to worry about? My warranty expires in June. Should I ask to talk to the regional PCNA rep? There were also a couple of other issues with the car the dealer could not replicate that were never addressed.
I noticed on the Boxter forum that cracked coils were found as a fault on a PPI.link
  • 7 months later...
In the future, mark the coil hold down screws with nail poilsh paint. If the paint is not cracked or broken, they did not remove the coils. If they don't tell the truth about one thing, when are they telling the truth?
