I noticed that my right side tail light was out. I tested the light bulb by switching it from side to side and the bulb turned out to be ok.
I finally tracked it down to the right side marker fuse (I think position A3). Trouble is, every time I replace it, immediately blows immediately.
I am not a sparkie by any stretch of the imagination. Where (and how) do I start looking?
Any suggestions on how I isolate that? Do I remove the circuit board and side marker and see it the fuse blows again?
Other than that, how do I check the circuit board itself?
I removed the side marker and the tail light circuit board tonight and put in a fresh fuse in.
When I switched the light switch on and POP.
So, I am assuming that the short is somewhere in the wiring harness.
Yes. As I said all lights go through the headlight switch so an internal short could cause that too.
I am trying to point out the obvious issues here - bulb sockets that are corroded and worn out headlight switches are the two most common (lights) problems on the 9x6 series cars.
Ok, I just went after a fresh batch of fuses and popped one in. When I turned the light switch to Park, the right side marker fuse (A3) popped again.
I still had the side marker and the tail light circuit off.
Does this mean that the switch is suspect? Or could it still be somewhere in the harness?
Ok, I found the problem. After A LOT of troubleshooting, I found that the front park light bulb had burnt out and fused against the socket. That caused the short.
The bulb that I pulled out of there looks strange though. I have not seen it before. Looks like the following: http://ep.yimg.com/ca/I/yhst-31825660550277_2185_27428520http://ep.yimg.com/ca/I/yhst-31825660550277_2185_27428520
I see that they are available on ebay, but cannot seem to find anything else about them. Anybody know?
Thanks for the help guys. I got the original part and installed it on both sides. Boy, those things are expensive. I wonder if they carve them out of diamonds.
It was frustrating not being able to drive with the nice weather we have been having, but I learnt quite a bit in the process
