2000 Boxster S. When the high beams are on the left turn signal indicator comes on and stays on (no flashing). The left turn indicator is very bright, the right turn indicator is also on, but dim. The left turn signal does not work.
There is also a problem with the rear tail lights - some times one side is out, some times the other side is out, some times neither is out.
What are the obvious places to look for ground issues (OK, so they are not obvious to me, that's why I'm asking.)
Any other suggestions?
Well, pulling out the left front headlight unit, unplugging, cleaning and plugging in what I could find seemed to have solved the problems with the front lights.
The tail lights are intermittent, so that's still a mystery.
