A week ago my clutch begin feeling a bit "squishy", shifting felt different and car would tremble a bit when begin moving on first gear. Next day I did the common clutch test...drove at 30-40 in 5th gear, nothing. But when I did the same on 4th the RPM began raising but the speed didn't ... so I'm assuming it is the clutch. My car is 2006 with 57K. I consider myself a good driver and don't abuse the clutch but I got the car with 30K, therefore, I can't say the same about the original owner.
Now, is there a way to ensure that the clutch is the issue before taking it a part? How do I know that isn't the clutch slave or master cilinder...or something else?
Thank you for your responses!!!!
Also, if it is the clutch...any issues with buying the kit from Sachs' brand?
And is there a how to replace a clutch guide on Renntech?
cheers!!!
Edited by leocanto
Hello,
If your RPM's increase and road speed stays the same the clutch is slipping. From what I have seen it is not uncommon for those cars to need the clutch replaced at that mileage. In addition to the clutch, the dual mass flywheel needs to be inspected at the same time. You should be able to move the flywheel surface no more than an inch clockwise then counter clockwise. While you are in there replace the flywheel seal and intermediate bearing flange seal. You could have oil on the clutch disc causing the slippage.
Take Care,
Aaron
cheers!!!
Sachs makes great stock clutches.
Aaron,
Do you think that I should replace the flywheel seal and intermediate bearing flange seal even if I don't have to replace the flywheel (I'm hoping not since I have not driven the car since I realized that it was slipping)? And if yes, do you know part no. for them or a link? (I could not find on pelican parts).
Thx!!!
I would do the seals regardless of whether or not it needs a flywheel, especially if it looks like they have been leaking. You will also need to pick up 8 flywheel bolts because they are one time use only bolts. The part numbers are as follows: Crankshaft Seal-99710121200, IMS gasket-99610511201, Flywheel Bolts-99907309201. If you do the iMS seal, be sure and follow the Porsche procedure for putting the engine on TDC. Let me know if you need anything else.
Best Wishes,
Aaron
My clutch was doing the same thing as yours.
I bought a Sach's kit for under 500 bucks and replaced it. No leakage at the IMS or RMS so I left them alone. I just cleaned the flywheel up with emery cloth without removing it.
New clutch works great.
There is a DIY somewhere on the internet on a 996 clutch replacement that I used as reference. Pretty straightforward job , although I struggled with realigning the gearbox for awhile.
I bought it here...http://www.gripforce.com/store/. They had a listing on e-bay.
$489.00 two years ago
I had trouble finding a 997 clutch alignment tool. Caused me all sorts of grief when I used a universal tool. The 996 tool will work...use it.
Who knows?
Very cheap clutch...very expensive release brg.
I'd go for it. Ask the clutch seller if he sells the alignment tool and if so ship it also. AT should be about 10 bucks.
