Hi trying to decode serial number on my 2004 911 with a replacement motor in 2010
its m96/03SAT66575200
I know the AT means re-manufactured/replacement, but I haven't seen SAT anywhere, any ideas? Also does the 665 mean it was rebuilt in 2005 or do all late replacement motors have 665?
Any idea what the "S" might be? I have a 2004 anniv, any idea if it might have to do with the x51 pkg? Can't seem to find anything about it
post-69878-0-69667100-1321233270_thumb.j
Logray confirmed this on RL
From him
The coding between your engine type and the beginning of the serial number are remanufactured engine code AT and the X51 designation 'S'. The next three digits of the serial number reflect the year of the engine.
66W is 1998
66X is 1999
66Y is 2000
661 through 665 is 2001 through 2005, respectively
your engine type is m96/03
"S" is X51 designation
"AT" designates remanufactured or Austauschmotor
665 designates 2005
Humm, that is contrary to how I have been reading the codes . I have the paperwork from the factory that came with the replacement motor in my car that the PO bought. My car is a 1999 and the serial number includes 66X. But the paperwork is dated December 23, 2005. I would think it is highly unlikely the factory built enough motors in 1999 to stay in stock for up to 5 years.
Complete serial number is M96.01AT66x66691 if someone can explain it better.
Edited by HalM
...unlikely the factory built enough motors in 1999 to stay in stock for up to 5 years. Complete serial number is M96.01AT66x66691 if someone can explain it better...
Porsche rebuilt (remaned) the 1999 engine in 2005, as best I can make out.
That engine was originally manufactured in 1999. It could have been (factory) rebuilt any time between 1999 and 2005 when it was put in your car.
Loren, thanks. That makes complete sense now. Much appreciated. :)
  • 2 months later...
Hi- Just had my engine replaced after IMS failure.... New serial number is M96/03 AT66569342
The 665 in the serial number says that it is a rebuilt MY2005 engine.
Based on this sequence number, it is likely the larger bearing was installed in the rebuilt engine.
Your sequence: 69342
Lowest sequence observed thus far with 22mm nut: 66526
Mind you, this is still just a guess... because the sequence number information is not public data.
As Loren states, impossible to tell for 100% certain without looking at it, because 2005 engine years were the first the larger bearing was observed, for the 2006 model years as well as replacements.
Thanks for he info! Now I just need the snow off the roads so I can get through the break in period :)
  • 13 years later...
Bonjour à tous,
Je suis français et viens d'arriver sur le Forum et je suis sur le point d'acheter une 40 Jahre 911...
Son Numéro de série moteur: M96/03 S AT 66 5 75255
Il s'agit donc d'un moteur X51 de remplacement fabriqué en 2005, je cherche à savoir si le roulement de l'IMS a été fiabilisé ou connaitre son diamètre.
Est-ce que quelqu'un peut m'aider ?
Merci beaucoup
4 hours ago, VPK45 said:
Bonjour à tous,
Merci beaucoup
Hello everyone,
I am French and just arrived on the Forum and I am about to buy a 40 Jahre 911...
Its Engine Serial Number: M96/03 S AT 66 5 75255
So this is a replacement X51 engine manufactured in 2005, I am trying to find out if the IMS bearing has been made more reliable or to know its diameter.
Can someone help me?
Thank you very much
The engine serial number would have been built in late 2005 or early 2006. Porsche rebuilt engines always get the latest parts and a warranty.
To be sure you would have to open the engine to get the IMD diameter. If you want insurance then you can install one of the 3rd party IMS oiler solutions.
LNENGINEERING.COM
IMS bearing failures are expensive. The IMS Solution is the only permanent solution to the IMS problem. Proven protection and the industry’s best warranty.
Because it is a 2005 engine, it would most likely have the oversized third generation IMS bearing in it, which means it cannot be removed without total disassembly of the engine because it will not fit through the opening in the engine cases. One way to know for sure would be to pull the trans, clutch and flywheel off and look at the nut on the IMS bearing center bolt; if it is 22 MM, you have the oversized bearing, which was the only one to use that large a nut.
