Error codes
I have a 2001 boxster 2.7, went to a DE last week, car started to misfire and when I got home I pulled with Durametric the following codes
P0139
P1126
P1128
P1130
P1133
Clear the codes, car misfires and loss power, pulled codes again and same codes come up. I clean the maf, still acting the same, any suggestions
P0139 Aging of Oxygen Sensor After TWC, Bank 1
Possible causes:
- Implausible signal from oxygen sensor
P1126 Oxygen Sensing Adaptation, Lower Load Range, Bank 1 – Above Limit
P1133 Oxygen Sensing Adaptation, Lower Load Range, Bank 2 – Above Limit
Possible causes:
– Incorrect signal from MAF sensor
– Intake air system leaking
– Fuel pressure too low
– Volume supply of fuel pump too low
– Fuel injectors fouled
P1128 Oxygen Sensing Adaptation, Idle Range, Bank 1 – Above Limit or Below Limit
P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Above Limitor Below Limit
Possible causes:
– Exhaust system leaking
