Hi, I have to replace the battery in my Cayman S in 2006. Someone able to explain the recovery procedures to be performed after the replacement?
thanks
I remember reading this:
1) You can end up with faults in some of the control units -- these should clear up after the new battery is installed.
2) Steering angle sensor:
Turn wheels straight forward
Switch ignition off and then on again twice
Turn engine on
From the straight ahead position, turn the wheel approx 20 deg to the right (past the straight ahead position)
Drive straight ahead for about 2 secs and at least 3 mph
This should reset itself.
3) Power windows:
Push and hold window switch to fully close window
Push switch once more (to close)
Repeat these steps, only to open window
Regards,
paul...
Turn engine on
3) Power windows:
Regards,
paul...
Thanks a lot!
