Hi windsurfnut, did u manage to solve your problem?, mine has just started to do exactly what urs was doing?,
I dismantled everything and put it back, and it works just once, and then stops.
  • 7 months later...
  • 6 months later...
Would like to refresh this thread.
i have a first genaration Cayenne S which stay for almost 2 years now without driving. I try to reactivate the car now. New battery and the car started. Some codes came up which i could clear.
The problem i still have is the gear selector. When the position is P the display still is showing "put selector to park position"
the key doesnt come out easy . I have to wiggle a bit.
i disconnected the gear selector to check what is going on there. I couldnt find any broken parts. Magnets are still in place.
so what it can be?
what is found out, when i am taking away the circuit board and putting the selector in P it works.  Dont show message on the display any the key is coming out with a click how it must be.
what could be the problem?
I just went through this after a penny fell into my shifter assembly. I found this and replaced the "sunshade" (the black rubber part with the magnets) and it works fine again now. http://www.pelicanparts.com/techarticles/Porsche-Cayenne/11-BODY-Shift_Gate_Trim_Replacement/11-BODY-Shift_Gate_Trim_Replacement.htm#Customer_Comments_Bookmark It is part #95555226500 for the 955's. Not sure if it changed for later models or not. Mine didn't seem to be broken, but it sure didn't work properly. I think it may only take a little bit for the magnets to get out of line with the circuit board and that is how it senses what position it "should be" in.
Also make sure you get the circuit board snapped back into the plastic liner above it securely. Otherwise it's going to droop down and get hung up on the magnets.
 It is a joy in finding the problem and fixing it!
The corroded wires are at front passenger side (Right hand side) under the carpet. Basically you will need to remove the front passenger seat completely and foot well then can flip over the carpet. You will see a bunch of wires passing through it to the front. Easy to find the corroded wires ( 2 spots) that only hand taped the terminals..the corrosion are there. Hope it helps!
Edited by paulwu
Thank you guys for your advice. Very welcome. About the black rubber part with the magnets i was thinking to because it was mentionend in a Pelican DIY. But it looked ok so i move on with my search. I will get a new one.
About wires under the front seat i didnt even think. Are we talking about the wires which passing the footwell inside this black plastic duct? Thank you
I am planning to change all the shifter assembly. Anybody did it? Something special i have to pay attention to? Anybody know if there is a adaption neccessary after that or this just drag and drop?! Thank you
I did the change of the complete shifting assembly but ended up not it; thus I have an assembly for sell if anyone interested in it!
There is no need for any adaptation but just drop and play. My case it was the corrosion of the wires I fixed the last then fixed all the issue including the key not release and the manual shifting issue.
Because i had a clogged sunroof drain and water on the floor thats s possibility. Just dont know which wires exactly you sre talking about.  Under the seat?
Check my post...it is in front passenger side (right hand side); flip over the carpet you will see the wires under it! Yes the wires are in the plastic duct.
Edited by paulwu
Please help. Dont want to destroy my shifter knob again by doing something wrong. I read a lot of post on different places. Still not shure if to proceed this job with shifter in "D" or in "N".
posts are confusing. What is the save way to do it?
thank you
Edited by ekstroemtj
Hi paul could you be more spacific regarding wires location in the harness? I had taken this all apart and unwrapped the harness to the point where it is secured to the firewall via zip tie and did not find and wires that where "hand taped" do i need to look further up on the harness closer to the firewall? Thank you
Edited by Frederick Vatter
Please post some pictures to see your harness; they are not close to firewall but around under the passenger side below the carpet.
