I recently acquired a 2005 (997) Carrera with 33K miles on the oddometer. I noticed that the black surface of the TEMP control dial seems to be peeling or chipping off, revealing the white surface beneath. Has anyone experienced a similar problem and if so, what might be the best way t go about restoring the black surface which appears to be slightly textured as opposed to a smooth finish?
Thank you for any help on this issue.
JK
