Window Regulator Repair
I’ve seen many topics about the Window Regulator for the 996/986. A lot of the topics deal with the window not lowering properly for the top, and also a grinding noise. The majority of the reasons for these symptoms are explained as a stretched/frayed cable. While this may be true in some cases, my window regulator exhibited these exact symptoms due to a broken plastic part. This seems to be a poor design decision to use this material. While for most people, I would recommend just replacing
Edited by Ross1
