2005 Carrera 2 Coupe:
The guide sleeve from my locking gas cap is missing. The pin pushes in and out with the locking of the doors, but the plastic sleeve is missing to guide the pin through the loop that is attached to the gas cap. I had the same problem with my 996 and it was an easy fix. I just can't find the part number anywhere. If anyone knows the part number I would appreciate the help.
Thank you,
JK
