I recently bought a 2008 cayenne with the rear camera option, my problem is that when i put the vehicle in reverse the camera pops out but my pcm screen dosent show an image. Only black with the red letters saying this should not replace looking over your shoulder.. I cheked the wiring and everyt,hing looks ok, the only thing that bothers me is that he camera is getting only 6V but im not sure what the correct voltage is. Any idead on how to solve my problem? Im out of warranty
where do you measure 6v? most likely your AV wire loose/broke in the camera. try to connect any av source (video camera, dvd player, or any other video source instead of your camera and see if you have a picture on PCM.
you can pull camera with the cover off the rear door. connectors are underneath
i pulled the cover and on the red and black wires going to the camera i measured 6V, i cheked the wires but they look good. how do i conect anything to the pcm if the video conector of camera is smaller? anyone sells a cable?
