Hi - I have looked through posts and I see some discussion on gauge fluctuation. My gauge fluctuates slightly when engine revs don't change - ie +/- 0.2 bar at constant revs - sometimes.
Is this normal? If not...
Is this likely to be the sender or conector or cables? If so, where abouts is the problem likely to be?
Derek
I know you said 'with RPMs constant', my dealer told me that at certain RPMs, the VarioCam Plus kicks in and ports oil to this system thus fluctuating oil pressure. You may just be seeing this.
