I have a 2001 Boxster S with the airbag light illuminated. I have reset the fault code but the light stays off only momentarily. The Durametric reads thus
airbag B05
module identification blue question mark
part number 996.618.219.02
supplier part number B05
current fault codes red question mark
27:
Ignition circuit passenger
Can anybody tell me how to repair this please
Fault codes 10, 11, 26, 27,39 -- Ignition circuit, passenger
Clear the fault memory.
Check whether the fault appears again.
- If the fault does not appear again, replace the passenger's airbag unit.
- If the fault appears again, check the wiring harness for pinches and chafing damage.
- If no fault is found on the wiring harness, replace the triggering unit
Thanks so much Loren Is there a tutorial on how to remove the passenger airbag? and how to find the harness etc?
