In turning off the headlights of my 2005 C2 997 with 33K miles on the oddometer I noticed there seemed to be a funny feeling in the switch. It wouldn't rotate freely to all the lighting positions. When pushing or pulling the switch to the in and out positions it felt loose, and the parking lights would flicker on and off quickly. I was not able to turn the switch to the off position. The best I could do was get it into the parking light position. Turning off the ignition resuted in the dash board warning about having the lights on. After 30 minutes of repeated attempts to shut the lights off, I drove it to a local independent. I had to leave the car there as they need to order a headlight switch. I was wondering if anyone else had a similar problem, and if so was the problem resolved by replacing the headlight switch.
Thank you for any help or advice on this issue.
no similar issues here but definitely sounds like your headlight switch is bad... having said that, they were/are known to go bad on the 9x6s which is of similar design.
If it truly is the switch that is of issue, you could easily DIY (and I hope your indy's labor charges reflect accordingly). All you need to do is push in on the dial knob, and turn it to the right ~ 1/8 turn. Then pull outward and entire switch comes out**. Quickly disconnect wiring harness and fit to new switch and reverse to insert.
** when turning the knob, it doesn't click or lock into a slot as you would expect it too. Just push it in and gently turn clockwise. Once it hits the right stop, pull outward.
Good luck :)
Thank you for the reply Cassiebox. I didn't know that the switch came out that easily. The DIY sounds simple enough. I did try turning it and there was so much resistance that I was afraid to exert too much pressure and perhaps cause further damage. It felt like there was an obstacle somewhere behind the switch causing it to lock up. Luckily I do have a warranty with a zero deductable, I just hope the repair is done correctly. It should be ready in a few days as waiting for the part is an issue. I just picked up the car a few days ago and am hoping there are no more unpleasant surprises. Your information is much appreciated.
Thank you again,
JK
