Good morning folks,
I was working yesterday installing a CAI and free-flow exhaust on my 01 996 c2 and out of nowhere the deck lid slammed shut with hand severing speed. I thought it might have been a gust of wind so I opened it back up and the same thing occurred.
Q: Are two dampers supposed to be present? I noticed fittings are on both right and left; however, I only have a damper on right side.
PS: leaves are at peak color in Asheville NC!!
The gas lifts are wore out and need to be replaced, but there should be 2 one on each side. Mine is the currently the same way and will slam shut with just looking at it.
Edited by rb101
FWIW, my '02 Cab with stock rear decklid has just one strut, on the RHS near the air box. I can see where a strut would attach (with some additional hardware) to the LHS but it's clear from the perfect condition of the paint that a strut or its hardware has never been located there. I suspect that one may need struts on both sides when running a modified or aftermarket decklid with a large/heavy wing on it.
When I purchased the car (about 2 years ago) it also had the "sudden close" feature, which a single new strut remedied perfectly.
Good luck.
The second strut (left side), is only used for the Turbo and C4S. The factory only installed the right side on non-Turbo and C4S cars.
