I discovered a small ding :( at the upper left side, of my right headlight; it's located at less than an inch from the contour headlight. The anomaly is not serious at all but I would like to repair it.
I was wondering if any of you could give me an advice on the proper way to remove this small ding ? As the ding is very close [less than 1 inch] to the contour headlight, do you think that it would be feasible to make the reparation by removing the headlight set and work underneath? Or do I have to unmount the complete front wing?
Thank you for your suggestions.
[my car is a 997 type]
I've had good success with the Dent- Pro. I costs about $20 at Pep Boys and works best for round or oval dents. It does not work for linear dents.
Good Luck
Sameer
Thanks for the info! my dent is linear...well if it doesn't work, I should go to the Porsche dealer and see if they have another solution. I must say I don't know what to do as of today.
