I had my top down today driving around on my new rear tires and when I went to close it I hit the rocker switch and nothing happens. I checked fuses d3 and b6 i believe they seem fine. Emergency brake is up and ignition on how can I trouble shoot getting my top up thanks /2000 boxster s
Does anyone know what the round disk under the front center collum with the sticky tape and looks like antenna wire is? I am using the same brake switch it was just stuck.
Could the disk effect the radio signal fading slightly. Thanks
