Thinking of getting some offroad tires for my CTT. Its on 20" factory wheels now. Maybe 17" wheels are too small to clear CTT's big brakes? Thanks.
Edited by TopGun2000
They are too small.
That's what I thought. So the smallest I can get away with is 18"?
Yes, 18" should be fine on your '04 CTT assuming you did not do anything with your stock brakes but double-check. Your on-board computer (when vehicle is not in motion) will actually list wheel options for you to set. You'll see 18". You can research wheel size and compatability here on Renntech -- OEM spec sheets, etc.
