Hello everybody, I am in a bit of a jam. 2000 Boxster, Dead Battery. Levers that open the trunk and Hood are in a "Locked " mode . So i can not open hood to change the battery. I grab the levers and they don't release, I don't remember this happening ever before. Any ideas as to where to start???
Go into the fuse box push and release the button with charging bolt graphic that will take positive jumper cable negative to the door catch this will give you just enough power to release hood latch to get to the battery for charging.
Hth
Rx4Mike
