Hello,
I have c2 1999 without traction control.
I got the car and it has 245/30/20 front and 275/30/20 rear. Now my rears are gone, and Im wondering if these sizes are ok, or should I go with something else on rear. Im not changing front tires
Assuming you keep the big wheels on the car, the closest diameter matching size that would fit requires a 10" rear wheel is 295/25/20. The 20" wheels really limit the sizes available. The tire I found in that size is Hankook Ventus V12 evo K110, which is not an N-rated tire either.
