Hey everyone,
I have a 2005 S with about 135K on it (almost all me :D ) and the engine is stalling out, almost as if it is being fuel starved, about 20-30 seconds after starting. For the first 20 seconds I can rev it and move it (small distance!) with what feels like normal power, but then it slowly (5-10 secs) had lower idle, becomes less responsive and then stalls.
All maintenance done, fuel/air filters changed, nearly full tank... My thought is the fuel pump...
Ideas?
If you also think fuel pump, anyone change it yet?
Thanks in advance!
Eric.
There are two fuel pumps. It's the main fuel pump which is the left pump that needs replacing. Change the fuel filter at the same time.
wvicary - what is the "logic" on which pump is running?
I know if you remove the fuse for one pump - the other one will run when you start the truck.. and vice-versa.. (this is handy for determining which pump is kaput..)
I thought the idea was to have two pumps since the tank is a saddle tank (two chambers with a high connecting passage between them) and one side will run low so the other side picks up, plus on a steep sideways incline gas will run to the lowest side of the tank, leaving the pump exposed on the other side..
Thanks all for the comments...
It was the left side fuel pump... Diagnosed via the pulling of the fuses method...
I ran totally out of time and needed the vehicle back, so actually went to the dealer, price was not TOO bad :huh: , but the convenience was there...
They have not had a lot of these go bad yet, so the writer was curious as to how I diagnosed it... :king: Thanks again everyone!
E.
