What exactly is the boost gauge measuring? Sorry if this is a silly question, but I know you guys will have great answers for this new Porsche owner.
The air pressure going into the intake manifold. This air is either the atmospheric pressure (about 14.7) when your reading indicate 0 or, if the turbo are delivering pressure, a bit higher. 0.6 to 0.8 for a base TT, 0.9 to 1.0 for an X50 and + for some modified cars (over 1.5 +). The amount of pressure delivered by the turbos is controlled by the ECU (electronic control unit) and the waste gate.
Edited by jpflip
another silly question:does a turbo ever read a vacuum in the intake?
The gauge in the car does not read vacuum however the engine does pull a vacuum in the plenum.
