Hello everyone. I'm attempting to replace the voltage regulator on my alternator, and as one of the steps need to remove my serpentine belt. It order to loosen the belt you are supposed to turn the 24mm bolt on the tensioner pulley clockwise. I've tried this and it looks like there may be a problem. After turning it many times and seeing nothing loosen, I reached the the back and felt whatever was carrying the tensioner pulley was also spinning. This is not good, right? Was this installed wrongly?
I assume it's the number 4 in the pic below:
Am I "screwed"? Any ideas on how to loosen the tensioner pulley?
