I have noticed a clear liquid that seems to stay/stained on the driveway. It is a clear liquid coming from the front of the car. Is this A/C related? Checked all the fluid levels and everything seems ok. Should I be concerned about this?
check your battery...there is a drain tube up front.
hope this helps
Aaron
What is the purpose of this liquid on the battery? Do I check from the bottom or the top? It seems to only leak after/ when the engine is turn on. Thanks for your help...
hope this helps
Aaron
The reason I say check your battery is on the passenger side of the battery there is a drain tube from your battery that drains pretty much straight down. If a problem exist with your battery this could be the reason that you have a "stained" driveway as water from the AC unit would not stain your driveway. Your gas tank is also located up front same with your steering box that has power steering fluid run to it. There are lots of little things to check out. Look for areas of moisture or dampness up front. Good luck in locating it.....let us know what you kind out.
I noticed the same thing last month. I was told it was a loose clamp on the wiper fluid hose. I also have a 2000 and apparently a new clamp was offered a while back but I only recently purchased my Boxster. It stoped leaking the next day.
