My 2003 Cayenne Turbo has just started giving me messages on the dash for PSM and Air Suspension and having read the codes got these:
1425 Pressure sensor (brakes)
1316 PSM Control Module
What do these two actually mean as the air suspension seems to work perfectly going up and down on the switch without a problem?
Pontypool
I have attached a link for the codes/descriptions. But I didn't find those codes at first glance...
P1914 Brake Booster Pressure Sensor - Signal Implausible/No Signal P1913 Brake Booster Pressure Sensor - Below Limit P1912 Brake Booster Pressure Sensor - Above Limit
http://www.renntech.org/forums/index.php?app=pcode&do=dme711&max_results=10&sort_key=number&sort_order=asc&search_keywords=&st=70
Thanks for the link but the two codes on my print-out don't seem to appear in the list :(
The list is for OBD 2 (emissions engine codes only).
P1912 Brake Booster Pressure Sensor – Above Limit
Possible cause of fault
- Short circuit to B+ in signal wire
- Short circuit to B+ in sensor ground
- Open circuit in sensor ground
- Brake booster pressure sensor faulty
- DME control module faulty
P1913 Brake Booster Pressure Sensor – Below Limit
- Short circuit to ground in signal wire
- Short circuit to ground in sensor ground
