I surrender!!! My top is just totally unrelaible and I want very much to make it manual and free of all vehicle microswitch interactions. I know this has been done. Could you please direct me to information to accomplish a manual top operation. Many many thanks
I would not recommend going all manual. I fixed a top recently by readjusting the center latch microswitch. It was a 5 minute job. But its you car. To go all manual - on each side, under the clam shell, there is a "V" shaped wheel directly above each rear tire that have two push rods attached to each of them. Pry off the push rods. The short one from the "V" and the longer one at it's most forward position. The top then can be opened and closed manually.
Edited by kbrandsma
