Can someone point me to an x74 installation how-to?
Also, why does every local dealer / reseller say x74 is discontinued?
I know available from Europe but with dollar vs. Euro rat it seems pretty expensive for 4 shocks and coils.
"The chassis and suspension, including the brake system of the 911 special model (M 095), has been adopted in its basic components from the 911 Carrera sports suspension. In order to achieve balanced handling as well as the familiar high level driving dynamics also on the special model, the rear axle springs have been adapted to the higher weight and resultant changes in driving dynamics"
So you already have a sport suspension. X74 will make that lower (about 40 mm front and 30 mm rear) and stiffer.
Installation couldn't be simpler since the X74 kit comes with springs and shocks already assembled. So you are just changing out strut assemblies and swaybars.
So if you look at the 996 DIY you can just skip the coil spring and shock disassembly/assembly.
