Hello
I have recently done the EvomSit solution ( ECU flash and installation of Air Flow Intake ) and when I do a hard acceleration ( 5 to 6 rpm) I loose all the power of the car ...RPM will be at ! or 2...the only way to recover from this situation is to re start the engine and everything is back to normal.
My dealer says that it is the Mass Air Flow Sensor however there is no faulty code.
Before I spend another 500 $ I would appreciate some comments
Many thanks
Thanks unfortunately I do not have the old one ..the new one is an Evoms Cold Air Intake quite different from the original one.
Which may exactly be the problem... ;)
Thanks for your advice...the problem is that I paid 1200$ to flash it however I may have no other choice but to put it ref lash at original state.
Thanks again
