So I've searched and couldn't find anything on this. The left an right headlight on my 2006 911 S Cab aren't at the same level. It's bugging me. The left side is noticably lower than the right side - which seems to be set to a good distance but not too high such that it would blind others. I am wondering how to bring up the left side a notch or two to align with the right. The leveling function works on both lights (tested turn on lights, then ignition and see the beams dipping down and coming up on both sides). What gives? Is this a dealer programming job or is there a good old adjustment screw somewhere. FYI, the car is new to me (whole story in and of itself - I can only say, never ever sell your Porsche because you think that Ferrari is going to be more fun ...:() so I don't know if they were ever aligned or not ...
Jay
Thanks Loren! Works like a charm. Shows you what one gets for looking at only the 1st level in the index (Headlights beam adjustment........................132). Of course 2 lines above it says "Headlights-> adjusting.............279,280). Well, goes to show that he who knows how to read has a clear advantage ... but to use the advantage you have to actually read ...
Thanks again!
Jay
