Howdy, I have a 1999 991 cabriolet and all of a sudden the other night it started running rough and then the check engine light came on. The next day the light went off and the car is running fine. I just got an OBDII reader and P1314 code came up. Code reads engine misfire cylinder 2, emission relevant. Should I panic here. I have put about 100 miles since then and the car is running fine. Please advise.
bigpeps52
P1314 Misfire, Cylinder 2, Emission Relevant
Possible causes:
- fouled, faulty or incorrect spark plugs
- contact resistance
- loose contacts
If the CEL is flashing you should not drive the car.
Check for a bad coil pack, bad spark plug connections, loose spark plug, or bad spark plug.
You can swap parts (one at a time) to another cyclinder and see if the fault follow the part.
bigpeps52
Wow! I was just going to post the same question (kind of). I have a MY03 996 Cab and yesterday after I filled up at the gas station the Check Engine light came on. I called for a service appointment but before I got home the light went off and it has not come on since. I am going to run it by the dealer to check the code but I know from other cars (not Porsche's) I have owned, something as simple as the gas cap not on tight enough can trigger a fault. Was it a coincidence that the mileage just turned over to exactly 49,800?
bigpeps52
Yes, just a coincidence!
Edited by kbrandsma
