Hey Everyone,
2006 997 Cab
Im looking for some diagnostic info on p1043 - Exhaust flap control final stage.. Complaints of a occasional stumble on accell are also noted.
Many thanks.
P1043 Electric air cleaner flap
Possible fault causes
- Short circuit to B+/ground or open circuit in the control line
- Open circuit of power supply to air cleaner flap solenoid valve
- Air cleaner flap solenoid valve faulty
- DME control module faulty
Thanks for the prompt reply..
This isn't the resonance flap in the center is it?
Otherwise I am not familiar with this electric flap fault. I can't pull any info on it
If I recall Correctly remember some newer models having a vacuum line to the air box. But I know this vehicle doesn't. Unless it's been eliminated.
Time for a POSIS update me thinks.
