I have a 2002 996 with 6 speed manual transmission that has a coolant system problem. The system has a slow leak when placed under vacuum at 25 psi but appears to hold pressure at when put under positive pressure at 13 psi. The coolant reservoir was replaced to eliminate a likely source of leaking coolant but this didn't solve the problem. The car does not leak coolant when it sits cold but does leak coolant on the drivers side of the engine bay when at operating temp. I put flurescent dye in the coolant and after being driven it looks like the source of the leak is in the vicinity of the AOS at the back left of the engine compartment. Is the AOS a potential source of leaking coolant and am I correct in replacing it as my next step? The car puts out a large cloud of white smoke at startup after sitting which I think also indicates that the AOS may be failing. Any advice would be appreciated.
Edited by harmonyroadporsche
