Hi there
With adding the green fluid it was easy to find the leak in my AC system. When the mechanic pumped out the AC fluid there was a certain amount of oil coming with it. He then filled it up with 900g AC fluid and the amount of oil he pumped out including the UV sensitve green fluid.
Now a few weeks later (the AC worked about a week) I could replace the condenser and dryer. For that the mechanic took out the fluid: 20g AC fluid left, 0 oil. When he filled it up again he added the 20cm3 of oil for the condenser and 900g of AC fluid.
Was that the correct decision or did some oil vanish with the AC fluid?
Ronny
