can anyone please pull up these part numbers?
996.552.509.00
996.552.279.00
it turns out the plastic arm broke which goes into the first part number but the first part number is rivoted into the 2nd and the felt on the back means both have to be replaced.
Dash parts? Do you have a picture of where they go?
Neither show on the current CGT parts list unless they are color code parts (ending in 9A4, or D12, etc.).
Hi Loren, they are the portion of the glove box door excluding the upholstery.
You've got a PM...
thanks loren. from the diagram, #22 looks like it is treated as one piece for replacement rather than being able to just replace the non-upholstered portion which contains the latching mechanism. and, dealer says the part numbers are not in the system. therefore they'll have to order a new glove box door in ascot. i hope that doesn't take too long since i have no glove until and it looks pretty cheesy with the door off.
