I installed a K & N cold air intake system in my 2003 996. During installation I disconnected the negative battery cable. After installation I reconnected the cable and began experiencing three fault codes: ABS, PSM and Check Engine. I was able to reset the check engine fault with the Durametric software but the ABS/PSM faults will not clear. The code is 5125: Incorrect data transfer from DME master control unit. Why did these faults occur to begin with and how do I remedy them?
  • 5 years later...
I have the same problem.I installed a K&N cold air intake and ever since my 2003 996 4s has a check engine light, and intermittent PSM and ABS fault codes which make the car run like poop. Help?
What codes are being shown?
