Hello,
I have just had a new battery fitted to my 996 C4 Cab. I do not have the code for the Sat Nav, the dealers do not have it on record? I have removed the unit and have the following information. Model: Becker Sat Nav, BE 2580, SERIAL NUMBER, 15075678, Can anyone help please?
Also I have changed the clock on the dash to the correct time but it keeps resetting itself back to the time before I re-set it?
The key battery has just been changed, but this has also started to work intermittently, it will unlock the car when it feels like? The bonnet release and roof button has also stopped working. I have just replaced the battery in this but it has not helped?? The seat keeps moving back to its original position when I do get the remote working? All very odd??
Any help would be appreciated.
:welcome:
From the Lost Radio Code FAQ...
Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC.
I suggest you try another dealer/OPC.
This topic is now closed to further replies.
